hi guys was shifting a bit of soil the night only got 7 or 8 bucket loaded in the trailer when a loud knocking sound started coming from the top of the engine any one got any idea what it could be? it starts and revs up well but the knocking get louder and faster when it's revs
The night b4 i ran it all night doing ditching with no bother!!
Any helps good
some help needed again please!
- Real name: john
Re: some help needed again please!
clouty wrote:hi guys was shifting a bit of soil the night only got 7 or 8 bucket loaded in the trailer when a loud knocking sound started coming from the top of the engine any one got any idea what it could be? it starts and revs up well but the knocking get louder and faster when it's revs
Any helps good
Hi
Is it the sound coming from the front or rear of the engine?
Piston slap (off the top of my head)?
I hope it is something simple to fix!
John
time travel wrote:clouty wrote:hi guys was shifting a bit of soil the night only got 7 or 8 bucket loaded in the trailer when a loud knocking sound started coming from the top of the engine any one got any idea what it could be? it starts and revs up well but the knocking get louder and faster when it's revs
Any helps good
Hi
John
sounds like its the top on engine??
Remove the rocker cover and see if there is any visible damage.Valves, pushrod bent.Hope its not too bad Excessive tappet clearance,perhaps an adjusting screw has backed off.That would account for the noise.
If valve gear looks to be OK it could be a "Diesel Knock" caused by a faulty injector.
Run the engine with each injector pipe slacked off on turn, see if you lose the knock.
If not it will allmost certainly be a piston problem.
cheers guys ill have a look the day
i did start it this morning from cold and ran for a good 10mins and the knocking didnt go away
cheers
cheers
Don't run it in that condition for long as it may make it worse,and more costly
- Real name: john
- Been thanked: 6 times
have a read here
3CX perkins engine developes a hammer sound
1982 3CX4 sitemaster
Users browsing this forum: No registered users and 56 guests
