hello im new to this. I was wondering if anyone knew were I would get a cast slew motor ring for a ford 550 digger.?
many thanks howard
ford 550 cast slew ring
- Real name: Mark Rive
- Has thanked: 33 times
- Been thanked: 26 times
Re: ford 550 cast slew ring
howie349 wrote:hello im new to this. I was wondering if anyone knew were I would get a cast slew motor ring for a ford 550 digger.?
many thanks howard
Hi Howie, i cant help you but I know there are a couple of members on here who certainly can. In the mean time, this link has some interesting reading and photo's. Also a couple of contact names and numbers for spares. Good luck, Mark
Rings are expensive and can be hard to get hold of. Search the net and try some machinery dealers.If you get one take care when fitting as they are very brittle,a hair line crack will render them useless.See previous postings.
Good luck
Good luck
- Real name: adam girdwood
hi martyn, finally got the ford slew working good!! been having some fun digging up stumps!! got a cast ring machined for £78 and replaced the seals too. next job now is replacing seals on steering rams!
howie349 wrote:hello mark. I cant see this link that you sent me. thanks howie
Damn computers, Sorry Howie, here it is
Ford 550 backhoe
adamgirdwood wrote:hi martyn, finally got the ford slew working good!! been having some fun digging up stumps!! got a cast ring machined for £78 and replaced the seals too. next job now is replacing seals on steering rams!
Looking good then
I was enquiring about a cast slew ring for a ford 550 digger. I got one from a local scrap yard. His name is james whitmen in ballynahinch co down. It cost £100. He has another two diggers if someone needs the same ring. Thanks for your help.
Users browsing this forum: Google Adsense [Bot] and 11 guests
