Hi everyone, I have a 3cx 4wd white cab about 1981 or so i think it has the Schindler axle in it but i would like to know has anyone ever replaced the top and bottom bearings on the hub or has anyone got a diagram or bearing numbers.
Many Thanks
4wd whitecab front axle
Topic author - Posts: 8
- Real name: john
- Real name: john
Re: 4wd whitecab front axle
Hi Mark
heres the serial no its a bit hard to make out as someone sprayed over it at some stage 3CX-4-2953.
Many thanks John
Many thanks John
- Real name: john
- Been thanked: 6 times
Mark.Rive wrote:Post your serial number and I'll post the parts diagram and the numbers Mark
Hi mark can you post up athe diagram and parts regarding the 4wheel drive steering pins/bushes, as my steering has a lot of play and i don't think they are the orginal pins, just bolts!!
my machine serial# is 295027
many thanks John
1982 3CX4 sitemaster
- Real name: Mark Rive
- Has thanked: 33 times
- Been thanked: 26 times
jcb3cx4wdwc wrote:Hi Mark
Many thanks John
That should do it if not let me know
jcb1968 wrote:Mark.Rive wrote:Post your serial number and I'll post the parts diagram and the numbers Mark
many thanks John
Here goes John, if its not the right one let me know mark
- Real name: john
Yes Mark it seems to be the correct one (3cxbj.pdf) but is there any one showing more of the hub on the drawing was hoping to get the bearing numbers.
Thanks again for your help
John
John
jcb3cx4wdwc wrote:Yes Mark it seems to be the correct one (3cxbj.pdf) but is there any one showing more of the hub on the drawing was hoping to get the bearing numbers.
John
Here you go
- Real name: john
