4/98NT engine blowing water out through the fill cap
Discuss loaders/backhoes here
Has thanked: 1295 times
Been thanked: 1111 times
Re: 4/98NT engine blowing water out through the fill cap
Post #11 by FOWLER MAN » Wed Apr 27, 2011 7:00 pm
jcb1968 wrote:Just found the following and my engine has the thermostat removed
http://leyland.conforums.com/index.cgi?board=general&action=print&num=1249737200
Yes, not only the Leylands, This was a a problem with many engines.
If we had to run without a thermostat in an emergency I got over the problem by fitting a thermostat housing gasket with a smaller centre hole. This restricted the flow and directed sufficient water through the rad. to keep the engine from overheating.
I hope the thermostat solves your problem.
I have had touble with these Leylands on more than one occasion, where they have over heated and the block has distorted and prevented the top of the liner sealing.
The bore at the top and bottom of the block become missaligned , the liner is tilted slightly and will not seal.
If the liner protrusion is carefully checked and is not even all round this could be the problem.
I have found no satifactory fix for this condition.
jcb1968
Real name: john
Been thanked: 6 times
Post #12 by jcb1968 » Wed Apr 27, 2011 11:28 pm
Fitted Thermostat today, and now the engine runs at a constant 82 all day
v
1982 3CX4 sitemaster
Return to “Loaders/Backhoes”
