Jcb 3c ii ram problem
Discuss loaders/backhoes here
browuk
Real name: Dave
Post #1 by browuk » Sat Jun 12, 2010 3:59 pm
Hi all, first post here, been lurking but not had to post until now.
My question, the top ram on my jcb backhoe will come in (push arm out) but only with relatively high revs then as soon as you let off the lever, it drops straight back, also, there is no power in it when digging it just wont pull the bucket through the dirt, all other movements work fine, its just this one,a hose burst on it a while ago and it sat doing nothing, have replaced hose now, Have topped up fluid but no go.
any ideas.
thanks
bsbplant
Real name: Brian
Been thanked: 6 times
Re: Jcb 3c ii ram problem
Post #2 by bsbplant » Sat Jun 12, 2010 4:29 pm
Ram seal gone inside the ram ??
browuk
Real name: Dave
Post #3 by browuk » Sat Jun 12, 2010 4:38 pm
bsbplant wrote:Ram seal gone inside the ram ??
Can anyone else confirm this is likely the problem and if so, how do I change it?
thanks again
Has thanked: 546 times
Been thanked: 358 times
Post #4 by essexpete » Sat Jun 12, 2010 6:06 pm
I suppose ther could be a spool leak but pistons seals most likely. Trapped air could be a problem. If you back a union and power it gently you could eliminate that. Usually cycling the ram will get rid of air. Don't get close to hydraulic oil squirting under pressure.
To change the piston seal will rquire the removal of the end cap which screws on. You will then have to pull out the rod with the gland and piston. You might find a seal kit with a JCB agent or independant specialist like Vicary plant. You might have a job undoing the end cap without the correct C spanner. I made something using an old heavy G clamp.
browuk
Real name: Dave
Post #5 by browuk » Sun Jun 13, 2010 4:43 pm
Hi thanks, been out at it today to take a look and the previous owner has welded the cap on the end so I aint gonna be getting to the seals, if it is the seals at fault, looks like I will have to replace the ram. on that note, before I take it off, does anyone know what this ram is called (boom possibly) and what is the approx weight?
steve ball
Real name: Steve Ball
Has thanked: 1 time
Post #6 by steve ball » Sun Jun 13, 2010 9:33 pm
The top ram's normally referred to as the dipper ram. I had to change mine recently and went for a reconditioned one.
The end cap on mine was also welded on (all the way around the circumference plus 2 x 1" wide straps welded from the end cap across the joint and onto the cylinder body!).
I would guess that it weighs in the order of 40 - 50 kg. It was fairly easy to change using a car engine hoist to take the weight whilst trying to drift the pins in. Take the opportunity to change the spring steel bushes at the same time.
browuk
Real name: Dave
Post #7 by browuk » Sun Jun 13, 2010 10:20 pm
steve ball wrote:The top ram's normally referred to as the dipper ram. I had to change mine recently and went for a reconditioned one.
Hi Steve, thanks for that, sounds like mine, its the same on the bucket ram too but thankfully that function well.
Do you mind me asking how much you paid for a recon one?
steve ball
Has thanked: 1 time
Post #8 by steve ball » Mon Jun 14, 2010 2:55 pm
The reconditioned ram cost me about £200.
Some places offer them on a service exchange basis but given the "bodge" that was performed on mine at some stage, this wasn't really an option.
browuk
Real name: Dave
Post #9 by browuk » Mon Jun 14, 2010 10:36 pm
£200 seems good but actually got myself a used one from breakers apparantly no problems with it and end cap untouched, paid £100 and sorted deliery to france for £38+vat so not bad if it fixes my problem.
TullyveeryClassicJCB
Real name: William Mulholland
Has thanked: 7 times
Been thanked: 42 times
Post #10 by TullyveeryClassicJCB » Tue Sep 28, 2010 2:27 pm
The Loader on my 3c3 is very weak and slow when raised and drops down slightly after raising. There is also a slight sound like a ping or crack when rising. How can I be sure the problem is with a ram and not with the valve block?
William
JCB Hydra Digger Loadall 65
JCB 3DIII Powertrain
JCB 3DIII (Manual)
JCB 3DII
JCB 3CIII
JCB 805B
Return to “Loaders/Backhoes”
