Definitive 3CX King Pin repair guide
- Real name: DGL
- Has thanked: 17 times
- Been thanked: 7 times
Re: Definitive 3CX King Pin repair guide
One/both of the slew ram seals has gone and the oil is getting past. This is then getting into the slew box and forcing what oil you have in there to come out.
- Real name: john
- Been thanked: 6 times
Hi Guys thanks for your help,
couple more questions,
Just spoke to my mechanic about the slew rams seals, he is hoping that there is no rust due to water ingress, any opinions on this?
Also there is a leak within the hydraclamp(not on the pipes) - is there a seal within the hydraclamps?, as this one appears to be leaking onto the rail, which is spilling onto the ground.
1982 3CX4 sitemaster
Topic author - Posts: 66
- Real name: Seamus
- Been thanked: 5 times
hmmm, I'm looking at the service manual here and I didn't find any direct reference to seals yet, you'd think there should be though.
I'll check further for you later on, I need to charge my lappy now!
MS
MS
Yes there is a seal in the clamp. It is effectively a piston that is tightening the bolt that goes through the rail. They are not difficult or expensive although the nut on the end can be difficult to shift. If it is weaping it needs changing because they can suddenly blow. You can get out of trouble on a temporary basis by by-passing one clamp.
- Real name: dylan jones
- Has thanked: 40 times
- Been thanked: 33 times
thought i would show a close up of the slew on my machine
- Real name: Seamus
Gees I much prefer that slewing arrangement than whats on my 3cx, no expensive king pins, racks, splines!!!
What model machine is that?
I'm mulling over a kingpost/slew refurb job, but if the back of mine was as simple as yours, there's be no decision necessary!!
its a italian machine called fai good look with your refurb, i have operated a few 180 machines and i think i would think my faviroute would be jcb 3cx turbo the old shape with square bonnet about late 80s, but the one i got is great and its something a bit different
- Real name: john
Hi Guys,
just an update
I have replaced my slew ram seals, and also the seal on the hydraclamp,
and can now confirm - no more topping up of hydraulic oil
just an update
hi if you are realy stuck for advise contact digger doctor he use to work for jcb he does second hand parts & new now he can guide you through it google it you will find him
good luck
good luck
