Mysterios metal in oil sump
Discuss loaders/backhoes here
CHRISEEBOY
Real name: CHRIS
Has thanked: 35 times
Re: Mysterios metal in oil sump
Post #11 by CHRISEEBOY » Sun Mar 07, 2021 9:41 pm
agrimax
Real name: R
Has thanked: 14 times
Been thanked: 191 times
Post #12 by agrimax » Sun Mar 07, 2021 10:38 pm
There is a bearing inside the engine oil pump idler drive gear,which would be behind the front timing cover. I don't know what type of bearing as I can't seem to find a close up picture of it...just a part number and diagram. 916/03300. Pt no.7 below.
Slooby
Real name: Tim
Has thanked: 191 times
Been thanked: 117 times
Post #13 by Slooby » Mon Mar 08, 2021 12:36 am
Now that is worth checking on
agrimax
Real name: R
Post #14 by agrimax » Mon Mar 08, 2021 12:43 am
A gear on the crank drives an idler(the one with a bearing in it),which then drives the pump gear.
CHRISEEBOY
Real name: CHRIS
Post #15 by CHRISEEBOY » Mon Mar 08, 2021 9:23 am
Can a bearing continue to function without its cage?
It looks like a lot of work to get to that part, plus Im assuming it would have to be pressed out/back in. If its been like that for years and worked normally, maybe I should just leave it alone for now?
agrimax
Real name: R
Post #16 by agrimax » Mon Mar 08, 2021 10:28 am
Think I would like to know where it came from tbh,if it was mine. A call to Charnleys and maybe send a picture to a mobile or email would confirm. I'd be surprised if they didn't know.
https://www.charnleys.com/
Has thanked: 1873 times
Been thanked: 1691 times
Post #17 by Jeremy Rowland » Mon Mar 08, 2021 10:50 am
CHRISEEBOY wrote:Can a bearing continue to function without its cage?
They would not put a cage on a bearing if it could function without one; this is worth checking out just to confirm one way or another.
gecko.cx
Real name: ian
Has thanked: 126 times
Been thanked: 114 times
Post #18 by gecko.cx » Mon Mar 08, 2021 2:48 pm
What ever it should be supporting - isn't.
I had a bearing fail on one side of an idler gear. I was still driving and hadn't noticed a problem.
When I drained the oil for a routing change, 28 half-gear teeth came out with the oil.
I'd caught it earlier enough and the two gears it meshed with were reusable.
If I'd ignored it a bit longer, both gears as well as the case would have been destroyed.
It's your call.
CHRISEEBOY
Real name: CHRIS
Post #19 by CHRISEEBOY » Mon Mar 08, 2021 3:08 pm
Ive emailed charnleys, will let you know what they say. Thanks everyone.
CHRISEEBOY
Real name: CHRIS
Post #20 by CHRISEEBOY » Tue Mar 16, 2021 7:01 pm
*UPDATE*
The experts at Charnleys tell me that the only thing it can be is the power steering idler bearing (number 21 on the diagram).
Fortunately I can get to this with the sump off, and sure enough there is a lot of play in the gear. My new questions are as follows:
1. It looks like its possible to get this bearing out through the sump. Am I right or is the only way to it through the front of the engine with the timing case off?
2. Once out, will the bearing need to be pressed out/in?
The bearing is that smooth part in front of the idler gear and it looks like if I can undo those two bolts it should come off?
Return to “Loaders/Backhoes”
