Does anyone know what this is for on the back actor, or whether something is missing from it?
What would this be for?
Topic author - Posts: 63
- Has thanked: 13 times
- Been thanked: 4 times
- Been thanked: 191 times
Re: What would this be for?
Spot on pete. Drain bung underneath on the big round plate. Probably be mostly water and gunge that'll run out.Unscrew the filler/breather(which incidently should have a cap on the top of it) and refill with HP 90 gear oil.(or whatever heavy gear oil comes to hand for that matter)
Edit...Forgot to say around 4.3l to refill.
- Real name: ian
- Has thanked: 126 times
- Been thanked: 114 times
Mine looked the same - if there should have been a cap to keep water out, mine was also missing it.
When I drained the slew box, I got 1.5L of nasty water and nothing else.
I couldn't get the plug out without destroying it (didn't seem a big loss!). I then fitted a poly plug which I'd drilled to take a cheap fuel filter. A short length of hose inverted at the top will hopefully keep water out for the future
Makes sense now, thanks for the replies. I shall have a look at draining it one day soon to see what comes out!
