essexpete wrote:Wow some serious fitting there! What where you pushing on for the top pin?
We are pulling it out with a hollow center cylinder, the round base plate is made up with a hole small enough so it pushes against the bush the pin sits in.
Deutz631 wrote:So the gearbox problem finally manifested itself.
It works fine when cold, but after it has warmed up it doesn't go into reverse.
If you let it cool down it works perfectly again and has real pushing power backwards wich leads me to believe the reverse clutch pack seems fine.
The reverse solenoid is activated when you select reverse at the lever. I checked with a magnetic field tester but they also detect small magnetic fields so if the solenoid is bad how would you test this ?
I am meaning to take the whole valve off and inspect it, because in the workshopmanual if you follow the transmission fault finder it says the solenoid valve needs looking at.
I ordered all the o-rings in august but the post has managed to loose them 3!! times after i paid the import duty 3 times .
Does anyone have any other clues to what could be goiing on?
I have also 3 questions,
How do you check the oil-level on the dipstick ? Its a 1991 grey cab synchro-shuttle. Everybody you ask has a different opinion. engine running or engine running and in forward gear. or engine not running ?
And how warm should the coolant get at working temp ? the temperature gauge goes up , stays in the green but just on the border of the orange. If i switch of the engine and feel the radiator , it's cold. Also the hoses to the radiator are cold. I replaced the waterpump , thermostat and the cap. i suspect the temperature switch might be faulty.
How do you operate the glow plugs or heater ? The ignition-key does'nt seem to have a preheat stop or anything and it is a bastard to start if it freezes.
Users browsing this forum: No registered users and 57 guests
