Jcb 3cx 1985 cab mounts
Topic author - Posts: 11
- Real name: kenneth moncrieff
Anybody know how to replace cab mounts. Big rubber between subframe and wheel arch. Bottom part completly perished.
- Real name: R
- Been thanked: 191 times
Re: Jcb 3cx 1985 cab mounts
Yip,loosen nut(probably cut off with grinder!) and jack up cab enough to get mounting up and out. Might need to undo other side as well.
Thanks. Have cut bolt off. Wasnt planning on replacing mount but am replacing lh and rg cab bottom rails as rusted away. Will see if there is any movement.
Done it this morning. Cut both bolts. Used a 5ft bar to lift back of cab and chocked it. Mount fits in with a bit of manipulation. Thanks
Users browsing this forum: Baidu [Spider] and 54 guests
