Jcb 215s (3cx) - how to I bleed steering after I didn't follow procedure :(
Discuss loaders/backhoes here
Nuggy00
Real name: Chris D
Post #1 by Nuggy00 » Thu Jul 19, 2018 1:32 pm
I rebuilt the front steering rams on my new 1998 jcb 215s (3cx) and bleeding them after was simple, just turned the steering wheel back and forth.... BUT I just rebuilt the rear steer rams and didn't read the bleeding procedure....
Now, after the rebuild of both rear cylinders, steering degraded quickly so no wheels turn at all.... I tried lifting it up on the loader bucket and stabilizers and turning wheels, and it still won't budge.... all other hydraulics work fine...
How do I bleed the system now???
Do I crack fittings one cylinder at a time in a specific order?
I think i put the hoses back the way they were. Feed from the valves is on the tire side of rams. The other two hoses on the cylinder cross outside to inside each cylinder. This matches a diagram a found online (different machine though)
Thanks for any help you can offer.
Nuggy00
Real name: Chris D
Re: Jcb 215s (3cx) - how to I bleed steering after I didn't follow procedure :(
Post #2 by Nuggy00 » Thu Jul 19, 2018 1:42 pm
Has thanked: 1197 times
Been thanked: 1027 times
Post #3 by Jeremy Rowland » Thu Jul 19, 2018 2:03 pm
Hi Chris hope you get it all working fine I hope somebody can point you in the right direction :thumbup:
Has thanked: 481 times
Been thanked: 303 times
Post #4 by essexpete » Thu Jul 19, 2018 11:44 pm
So have you an all wheel steer machine?
Nuggy00
Real name: Chris D
Post #5 by Nuggy00 » Fri Jul 20, 2018 12:04 am
Yes, just fixed it. The steering synch was off. I lifted the rear axle center position switch, the solenoid clicked and steering immediately reset. Easily switched modes and steered right and left after that, bled very fast
Has thanked: 1018 times
Been thanked: 910 times
Post #6 by FOWLER MAN » Fri Jul 20, 2018 2:00 am
Bit late with this but the bleeding sequence is as below:-
Return to “Loaders/Backhoes”
