Ford 550 Output Shaft Bearing Retainer
Posted: Sat Oct 21, 2017 12:00 am
Guys,
I just purchased a '76 Ford 550 TLB. The gasket in between the rear end and transmission was pretty much gone. So we have pulled the unit apart to replace and decided to replace the Output Shaft seal and gasket while we were in there. I have removed the 4 bolts from the ratainer but it will not come off. I am afraid of hurting the sleeve and shaft so i am trying to be real gentle with it but still trying to pull it off. Is there something I am missing? Do I have to remove the shift forks and shaft first? I cant find anything online about it, and the manual just talks about the four bolts.
Hopefully one of you guys can point me in the right direction.
Thanks.
Thanks.
