Hymac leyland engine fuel filter change
Discuss loaders/backhoes here
arrolman
Real name: Iain
Been thanked: 1 time
Post #1 by arrolman » Mon Apr 18, 2016 3:08 pm
Hi all,
Replaced the fuel filter this morning but cant get engine to fire. Battery has near enough died now so will charge it up overnight. Theres no manual fuel pump so I filled filter with new diesel, cracked the injector bleed screw and the injector pump bleed screw, both have fuel coming out but the engine wont fire? Worth cracking an injector as well? Fuel filter is seated correctly and looks to be no problems with that
Cheers,
Iain
TullyveeryClassicJCB
Real name: William Mulholland
Has thanked: 7 times
Been thanked: 42 times
Re: Hymac leyland engine fuel filter change
Post #2 by TullyveeryClassicJCB » Mon Apr 18, 2016 4:42 pm
Have you slackened the injector pipe unions?
William
JCB Hydra Digger Loadall 65
JCB 3DIII Powertrain
JCB 3DIII (Manual)
JCB 3DII
JCB 3CIII
JCB 805B
arrolman
Real name: Iain
Post #3 by arrolman » Mon Apr 18, 2016 4:51 pm
Cracked one before I totalled flattened the battery and there was loads of air coming out, going to crack them all tomorrow and see how it goes. Going to have to drain the fuel tank as the amount of crap in the old filter was shocking, dont know how it was still running.
Cheers,
Iain
agrimax
Real name: R
Has thanked: 11 times
Been thanked: 89 times
Post #4 by agrimax » Mon Apr 18, 2016 4:57 pm
Strange there is no manual lift pump on a Leyland engine? Or is the manual lever just broken off it?
Post #5 by TullyveeryClassicJCB » Mon Apr 18, 2016 7:12 pm
Draining the tank is all for nothing if you don't remove the inspection plate on the tank and clean out the inside. The tank on a Hymac doesn't usually give that much bother with dirt because of the shape of it. Tandem fuel filters and sediment bowls should be all you need.
William
JCB 3DIII (Manual)
JCB 3DII
JCB 3CIII
JCB 805B
arrolman
Real name: Iain
Post #6 by arrolman » Mon Apr 18, 2016 7:54 pm
Theres no manual lift pump anywhere that I can see. My machine only has a single fuel filter on the offside, not the twin setup that I presumed it should have when I bought it.
Cheers,
Iain
Mrsmackpaul
Real name: Paul Griffiths
Has thanked: 384 times
Been thanked: 253 times
Post #7 by Mrsmackpaul » Mon Apr 18, 2016 9:31 pm
what Leyland Motor ?? 6 98 I have owned had bleed screw on the block side of the injector pump you couldnt see and it was a real bugger to start if you didnt bleed it there as well this one had a lift pump though so Im guessing a different motor
arrolman
Real name: Iain
Post #8 by arrolman » Mon Apr 18, 2016 10:24 pm
Believe its the 4/98? Will stick some pictures up tomorrow
Cheers,
Iain
Mrsmackpaul
Post #9 by Mrsmackpaul » Tue Apr 19, 2016 12:53 am
whats it in and picture may help
agrimax
Real name: R
Post #10 by agrimax » Fri Apr 22, 2016 10:10 pm
Any further developments on the starting of this engine or pictures?
Return to “Loaders/Backhoes”
