looking for some advice , what year would this machine be ,machine serial no 49244 tractor ser no 65b120365 engine ser no 22099 ? what pressure should be in front and rear tyres ? cab is rotten ,are there any replacement cabs available , if not would it be a bad idea to build one but with a straight front window instead of slooping ? where to get piece of metal to repair front of bucket ? thanks in antisipation
jcb 3c mk2
Topic author - Posts: 2
- Real name: geoffrey mark
- Has thanked: 4 times
- Real name: martyn henley
- Has thanked: 38 times
- Been thanked: 50 times
Re: jcb 3c mk2
Hi Geoffrey, machine looks like an 1968 3Cmk2, first of the mk2's, i think i am right in saying that they only made this style for about a year, the story goes, drivers complained about cab, as 3c mk1 operators were bashing their heads on the windscreen, as they were used to front sloping windows, so they brought out the new improved version, with front sloping windows and altered design around the toolbox/fuel filler, with an improved middle step... which stayed through out the mk2' models.
As for tyre pressure, you might answer in here.
http://www.classicmachinery.net/forum/app.php/dl_ext/?view=detail&df_id=45
Hope this helps
Hope this helps
- Real name: Christopher Bremner
- Has thanked: 13 times
- Been thanked: 10 times
Re: jcb 3c mk2
there's one of those with same shape cab up beside me. I am hoping to get a look at it soon to see what condition its in.
- Has thanked: 76 times
Re: jcb 3c mk2
Just lately there have been a couple of the later 3c mk2 cabs on Ebay in fairly reasonable condition i am pretty sure that the later type will fit, they are only held on with 4 or 6 bolts.
- Has thanked: 7 times
- Been thanked: 43 times
Re: jcb 3c mk2
Martyn Henley is back! Great to see you posting on here again.
This would have to be an early 69. This style of 3C with the triangle refuelling door and door step was the standard style of 1968. 1969 heralded the change to the more typical body style of the mk2 3C.
William
JCB Hydra Digger Loadall 65
JCB 3DIII Powertrain
JCB 3DIII (Manual)
JCB 3DII
JCB 3CIII
JCB 805B
JCB 3DIII (Manual)
JCB 3DII
JCB 3CIII
JCB 805B
Users browsing this forum: No registered users and 67 guests
