Hi all
I wondered if anybody could tell me if the backhoe assembly is the same on a mk2 as it is on a mk3, and if not what are the differences
Thanks for any answers
jcb 3c back hoe
- Has thanked: 7 times
- Been thanked: 43 times
Re: jcb 3c back hoe
There are differences and similarities. In fact there are differences between early mk2's and later mk2's. Which aspect of the assembly are you referring to?
William
JCB Hydra Digger Loadall 65
JCB 3DIII Powertrain
JCB 3DIII (Manual)
JCB 3DII
JCB 3CIII
JCB 805B
JCB 3DIII (Manual)
JCB 3DII
JCB 3CIII
JCB 805B
Topic author - Posts: 27
- Real name: Tom
- Been thanked: 4 times
Re: jcb 3c back hoe
Well I have a mk 3 but the slew gear has broken up, so I purchased a whole back actor that I knew was in a hedge on a farm I know, it has the king post, boom, dipper and all rams etc so I thought it would be easier to replace the whole lot rather than fix mine also it was cheap, how ever I'm not sure what it is of it looks the same as mine but I know that the mk2 and 3 look very similar, i plan to remove mine at the hydra clamps and fit this straight on but I thought that I better check that it will fit first
Re: jcb 3c back hoe
It will fit providing it is a later mk2 back actor and not an early mk2. The early mk2 ones didn't have hydra clamps.
Just to note the slewing gear on a mk3 was upgraded from the mk2 and do look different. The slew pots have rounded ends compared to the flat ends on a mk2.
William
JCB 3DIII (Manual)
JCB 3DII
JCB 3CIII
JCB 805B
JCB 3DIII (Manual)
JCB 3DII
JCB 3CIII
JCB 805B
- Real name: Tom
Re: jcb 3c back hoe
I think it must be from a later mk11 then as it still has the hydra clamps attached to the hoses but the slew pots are flat on the ends, i did notice that about the pots before that's what got me wondering, should have a busy weekend then as I also have front wheel bearings to change
Thank you very much for your help
