Just been under the rear of the machine and it appears my right handside rear wheel is covered in oil. I can see it actually dripping from the axle as such.
Any ideas what could be causing this and is it something that is "easy" to fix?
JCB 3C MkIII Rear Wheel covered in oil...
- Real name: phil wheelton
Re: JCB 3C MkIII Rear Wheel covered in oil...
sounds like the oil seal is leaking in the end of the halfshaft which transmission / axle set up have you got, is it the Leyland or JCB's own rear axle?...
philwheelton wrote:sounds like the oil seal is leaking in the end of the halfshaft which transmission / axle set up have you got, is it the Leyland or JCB's own rear axle?...
Have you got a separate prop shaft?
- Has thanked: 7 times
- Been thanked: 43 times
Woody's digger has the Brockhouse Build 3 torque so would be the Leyland axle.
William
JCB Hydra Digger Loadall 65
JCB 3DIII Powertrain
JCB 3DIII (Manual)
JCB 3DII
JCB 3CIII
JCB 805B
JCB 3DIII (Manual)
JCB 3DII
JCB 3CIII
JCB 805B
Topic author - Posts: 113
- Real name: Liam
- Been thanked: 4 times
Thanks Tullyveery
Here are some photos anyway.
The other wheel is completely dry.
ETA - there is no visible rear prop shaft.
Mines is about the same (keep putting it off), not a big job to do if it was the Leyland tractor but more of a job on a JCB
- Real name: Liam
Ah, so I'm still ok to use it? Didn't want to drain the axle dry.
Is it the hub seal that's gone then? I'm leaning towards getting someone in to fix it, as I don't like the idea of 7tonne of steel without a wheel on it, above my head...
- Real name: Hubert Mooney
- Has thanked: 3 times
- Been thanked: 6 times
Remove floor plates. Jack machine up. Remove wheel. Drain oil out of rear axle. Remove heavy plate at rear of axle. Might need assistance with this. Inside you will find a large nut held on with a split pin. Remove pin & nut. Half shaft should pull out. Prize seals out of axle housing. Replace seals and fit half shaft taking end float out of half shaft. Do not over tighten.
