3CX Transmission Strainers
Topic author - Posts: 689
- Has thanked: 7 times
- Been thanked: 43 times
Does the transmission strainer in the sump of the early 3CX often get clogged up? Would a symptom of a clogged up strainer be simply a lack of power?
William
JCB Hydra Digger Loadall 65
JCB 3DIII Powertrain
JCB 3DIII (Manual)
JCB 3DII
JCB 3CIII
JCB 805B
JCB 3DIII (Manual)
JCB 3DII
JCB 3CIII
JCB 805B
- Real name: phil wheelton
- Been thanked: 29 times
Re: 3CX Transmission Strainers
Yes it can but they are often clogged up by bits off clutch packs, is it the borge warner shuttle or the JCB electric box ?
The Borg Warner box. So, generally speaking, if you had a clogged up strainer you would have clutch packs in need of replacement?
William
JCB 3DIII (Manual)
JCB 3DII
JCB 3CIII
JCB 805B
JCB 3DIII (Manual)
JCB 3DII
JCB 3CIII
JCB 805B
- Been thanked: 685 times
Phil is almost certainly right, has your model got a filter in the system as that might give you a clue? Does the oil look normal? If you pull out the dip and drip some oil onto white tissue paper that might give an indication of oil state.
Users browsing this forum: No registered users and 63 guests
