JCB 3C2 - Rear axle seal questions?
Yozza
Has thanked: 3 times
Post #1 by Yozza » Mon May 12, 2014 10:35 pm
Hi folks,
My rear axle seals leak like a good un, just had to put 2 gallons of oil back in the box :shock:
Do any of you knowledgeable folk know if I can get away with taking the rear wheels off and replacing the seals with no serious dismantling? If so, are these seals listed on fleabay the correct size and type?
http://www.ebay.co.uk/itm/3685-JCB-Hub-Seal-JCB-3C-82mm-x-120mm-x-12mm-/140999513332?ssPageName=ADME:X:RTQ:GB:1123
Yozza
agrimax
Real name: R
Has thanked: 11 times
Been thanked: 90 times
Re: JCB 3C2 - Rear axle seal questions?
Post #2 by agrimax » Tue May 13, 2014 1:05 am
Can't fit the seals without pulling out the half shafts.Have to remove the rear cover off the diff housing to then remove the nut on the end of the shaft to pull it out.Would think the bearing will need heated/pulled off the shaft to allow the seal on then.Not quite sure.
The correct seals will be imperial.If you convert the sizes above(apart from the width) to inches,they are slightly different to the pt no. ATJ1024,which is for Leyland tractors but should be the same as JCB.
Yozza
Post #3 by Yozza » Wed May 14, 2014 1:18 pm
Thanks for the answer. Sounds like a biggish job, I'll keep toping up the gearbox oil.
Cheers,
Yozza
hubert
Real name: Hubert Mooney
Has thanked: 2 times
Been thanked: 5 times
Post #4 by hubert » Sat May 17, 2014 11:06 pm
Done this job and from memory agrimax is correct. I think there are two seals on each side.
hubert
Post #5 by hubert » Sat May 17, 2014 11:07 pm
