jcb 3c 111 powertrain back actor oil refil
hi all new to the forum just purchased a 3c for scrap money,been trying to change gear oil in back actor,do you refill it through the allen bolt or through the bolt with the overflow pipe i cant seem to get any oil in after takeing allen bolt out any advise i would be gratefull,also the brakes are crap they are the dry brake type,i was also wondering how to drain the torque converter all the oil dont seem to come out.
- Real name: phil wheelton
- Been thanked: 29 times
Re: jcb 3c 111 powertrain back actor oil refil
Is there a plate with a small pipe bolted to it, if so take the plate off and fill the oil through there.
- Has thanked: 849 times
- Been thanked: 680 times
I believe the very early Power Train build 5 were dry brakes and dry brakes seem generally to be poor. I think the dry brakes also had adjusters accessed thro the cab floor.
tried adjusting so they just lock on, then take took them back 1 turn, no brakes at all.although when i try and bleed them theres pleanty of fluid coming out of the bleed screws.
