William
It does point to valve block problem,can you get hold of a test guage to check the pressures ? also it may be that you have worn seals in the rams.
What I would do is,start from the beginning,oil condition level,filters.etc
Does your hydraulic pump squeel ? Try to get hold of a valve block as there must be a few breaker machines around.
Good luck
Jcb 3c ii ram problem
- Has thanked: 7 times
- Been thanked: 43 times
Re: Jcb 3c ii ram problem
The oil level, condition and filter is all fine. Im beginning to think the valve block is where I should start. In my other diggers between "raise" and "level raise" there is like a resistance a barrier that you have to pull the lever through to get to the level raise position. In this digger the lever just goes straight through "raise" and into "level raise."
William
JCB Hydra Digger Loadall 65
JCB 3DIII Powertrain
JCB 3DIII (Manual)
JCB 3DII
JCB 3CIII
JCB 805B
JCB 3DIII (Manual)
JCB 3DII
JCB 3CIII
JCB 805B
Norman, i'll do that before I do anything. I hope it isnt the valve block. It looks a real bitch to take out.
William
JCB 3DIII (Manual)
JCB 3DII
JCB 3CIII
JCB 805B
JCB 3DIII (Manual)
JCB 3DII
JCB 3CIII
JCB 805B
I swapped the hoses around on the valve block and its made no difference. With the bucket raised it still drops a bit. Time to whip out the rams! The bottom pins look like real bitches.
William
JCB 3DIII (Manual)
JCB 3DII
JCB 3CIII
JCB 805B
JCB 3DIII (Manual)
JCB 3DII
JCB 3CIII
JCB 805B
Can you leave the cylinders in place and just remove the caps and rods ?
Users browsing this forum: No registered users and 67 guests
