JCB 3cx project 8 not moving forward/backwards
gandamaluco
Real name: Hélio Sequeira
Flag: Portugal
Post #1 by gandamaluco » Tue Feb 23, 2021 10:47 pm
Hello guys
I am sorry to bring this subject up again, which has certainly been discussed many times. My 3cx project 8 suddenly stopped moving forward or backward. I was normally running in 4gear on a downhill road. before entering the hangar I engaged 2 gear while waiting for the gate to open and pushed the powershift lever forward but the machine did not advance. it was static in the middle of the road and doesn't move. I didn't hear any strange noises or do anything different, the machine just don't do anything. The gears go well but the shuttle does not take efect...
Any idea?
gecko.cx
Real name: ian
Has thanked: 22 times
Been thanked: 15 times
Re: JCB 3cx project 8 not moving forward/backwards
Post #2 by gecko.cx » Wed Feb 24, 2021 1:47 am
Check fuse C6 ('C' is the first column, not the third).
All of my fuses have slight corrosion on the contacts, so I've used needle-nosed pliers to pull each fuse and reseat it to scrape the contact clean.
Give each one a visual inspection while you are at it and replace any that look less than perfect.
gandamaluco
Flag: Portugal
Post #3 by gandamaluco » Wed Feb 24, 2021 10:39 am
Hi geko
Thanks for the reply. Lights and engine were all ok and hidráulics worked fine. I managed to entered it on the hangar with the back hohe. Gonna take a close look at ir this morning.
I'll coment to you late....
gandamaluco
Flag: Portugal
Post #4 by gandamaluco » Wed Feb 24, 2021 12:05 pm
Geko
You are awesome. Changed the fuse and all seems to BE fine again.
Thanks só much
gecko.cx
Real name: ian
Post #5 by gecko.cx » Fri Feb 26, 2021 2:42 pm
That's great - that was the easy version!
Glad to help.
gandamaluco
Flag: Portugal
Post #6 by gandamaluco » Sun Feb 28, 2021 4:44 pm
Here are the photos of the relay fuse box.
gandamaluco
Flag: Portugal
Post #7 by gandamaluco » Sun Feb 28, 2021 4:50 pm
By the way, do you know what is this for and the right way to connect that Wire... It was loosen and i just plugged it that way but don't know if that's the right way. Do you know the function or what's for?
gecko.cx
Real name: ian
Post #8 by gecko.cx » Tue Mar 02, 2021 2:09 pm
Mine looked just as bad with one wire broken. I cut the two wires back and built an extension. The connector is an EV1 commonly used on fuel injectors, but the standard version won't fit inside that housing. This is the one I ordered and latches correctly while still being able to release it.
https://www.aliexpress.com/item/32686040728.html
