Im looking for an old Thwaites Tusker Digger if anyone knows of one for sale?
Tatty is good, as long as it runs and doesnt have any serious problems.
Ideally in Scotland, but would travel anywhere for the right machine.
Not after a show stopper - I want something I can put to work and play with at the weekends )
Also after a running but unrestored Petter AVA1.
Many thanks
Thwaites Tusker Digger Wanted
Forum rules
[For sale]
[Wanted]
[Exchange]
[Swap]
[For sale]
[Wanted]
[Exchange]
[Swap]
Topic author - Posts: 19
- Real name: Ben
- Real name: john todd
- Been thanked: 3 times
Re: Thwaites Tusker Digger Wanted
2 on ebay search diggers, then farming. theres two on there expect to pay £850 - £1200
- Real name: Ben
Thanks chaps - I do ebay but Il check the mag too.
I clocked the one on Ebay, but only the one?? Suspect the other finished a day or two ago - if so I viewed it before it went on Ebay. The chap told me it was a good runner, but when I got there it was a wreck. It hadnt ran for several years, bits missing, couldnt test anything as Id taken no tools etc - I was so p****d off after my 200 mile round trip that I walked away in disgust, even though he was only asking £400. Foolish in hindsight, but I do wish folk would be honest with their descriptions!
- Real name: Ben
- Real name: Ben
- Real name: brian sugden
i have a tusker - not for sale though - but if any one can tell me how to get the clutch apart i would be very grateful - also if i wanted to put it on the road , is it a dumper or a digger ? [ for registration purposes ]
in fact if anyone can tell me anything about my ' machine ' i would again be very grateful
- Real name: Ben
Hi - I cant help you with the clutch Im afraid, but I would think it needs to be registered as a digger. Not sure if you would need to add an alternator and a light pack for road use?
I dont know much about them either - other than they were originally supplied with both digging arm and dumper bucket, so you could swap them as you wish. I cant believe many folk did though, as one without the other is a bit US. Just a couple of pins hold the whole attachemnt on though, so its easy enough.
Main problem they have is the lack of weight over the back end - its VERY easy to tip yourself over the front even with the stabilizers right down. Im building a frame out back on mine in which I will stack 20+ dense blocks to try and keep the back end down a bit.
Overall weight for transport by the way is about 1.6 ton.
Im after a wide ditching bucket and a narrow trenching bucket for mine if anyone has any for sale.
braveheart! wrote:i have a tusker - not for sale though - but if any one can tell me how to get the clutch apart i would be very grateful - also if i wanted to put it on the road , is it a dumper or a digger ? [ for registration purposes ]
I too have a tusker (not for sale), well worn but starts well and still does it's job albeit in a rather unsophisticated way.
Re the clutch, it is not a conventional system but in fact a pair of brake shoes and a drum. I checked mine over last year when I removed the gearbox to replace a bearing and seals. Remove the rear panel (where you stick the starting handle) and you will see the clutch release mechanism and tinwork cowling. Under there is a roller chain and sprockets, I can't remember all the details of disassembly but logic and common sense will kick in when you get this far. If you need more help feel free to ask and I will try and get my memory box kickstarted.
Cheers,
Nev.
