I have recently bought this tractor and it has a few mods so I am trying to figure out where to put the hydraulic oil as I can't see a filler bung. A hydraulic fitting is attached, could be the dump, so I am thinking I will remove it and chuck some oil in see if the level on the dipstick goes up. Good idea??
I am looking for the oil pressure switch, no wiring going anywhere that looks promising. Pulled out a fitting just beneath the fuel filters on left side of engine but it just was a nut with a hole in it and something stuck in the hole, looks dodgey to me but I reckon it could be where the oil pressure switch should be. Any ideas?
Where is the transmission filled, can only see a likely bung type nut under the seat on the left?
Does anyone know where to get a free service manual? or a schematic showing all the tractor service points?
Thanks for any help guys
Case David Brown 1290 Help required
Topic author - Posts: 5
- Real name: Jack Spratt
Re: Case David Brown 1290 Help required
Or here: http://farmingforum.co.uk/forums/forumdisplay.php?f=21
It may take a while for the mods to sign you in but a wealth of tractor knowledge.
Also as first reply:http://www.dbtc.co.uk/index.php?name=PNphpBB2&file=viewtopic&p=57962
Thanks essexpete that link was a great help. Confirmed pretty much what I was thinking re the hydraulic oil filler. Mine has been used as a return as well. Cheers
