Fowler VF and TS 69 Hexatrac
Topic author - Posts: 68
- Real name: Nick
- Been thanked: 4 times
Have seen some photos and discussion re TS 69 ploughs on this board. Thought you might like to see just how much a little 40hp crawler will pull.
- Real name: martyn henley
- Has thanked: 38 times
- Been thanked: 50 times
- Real name: Nick Drew
- Has thanked: 437 times
- Been thanked: 208 times
Re: Fowler VF and TS 69 Hexatrac
Not another Nick !!!
Seriously though welcome to the board Nick
Nick
Nick
Wow! Does beg the question of what is sometimes achieved by great heavy wheeled tractors.
Is that a 6 or 7f, what width furrows and what type of soil are you on?
Regards ep
On second look it looks like a 6f?
Regards ep
- Real name: Nick
6 furrows, 12" wide. On that day we were about 9 to 10" deep as the ground was soft and the landwheels were sinking in. YL 183 bodies. Medium loam soil but that part of the field was a bit sticky. In fairness this is a bottom gear only job, she handles it fine; trying 2nd gear makes it really bark and whistle and the driver gets completely covered in soot as opposed to just the traditional Marshall Measles of spots of oil. Then again 40 hp is about all they ever put out when they were new, so just how many are still pulling after 60 years is another question!
- Real name: Richard
- Has thanked: 28 times
- Been thanked: 46 times
essexpete wrote:Wow! Does beg the question of what is sometimes achieved by great heavy wheeled tractors.
More productivity & less operator fatigue.....but I doubt a new John Deere will will quadruple its value after 60 yrs
Yes Richard, having once spent a whole autumn on an old IH BTD6 discing (and not sure whether or not it was better or worse without cab)
I do remember hankering after a Q cab and radio at the time!
Hello Nick
I like those Fowlers,great engine beat.And they hold their value well.
- Real name: Nick
Engine beat is one way of describing it, rock and roll is nearer the mark!! The bounce on a Marshall wheel tractor causes the whole tractor to rock back and forward; on a track machine most of that bounce seems to be absorbed by the driver. That and the starting routine means that a few hours driving this and you're stiff for a week. Since the engine rebuild we have only used the cartridge start a couple of times (mostly just for fun). You need courage and determination to swing the beast, you have to put your back into it and get it turning over fairly rapidly, knowing all the time that the decompressor is going to kick out and then the moment of truth; either she fires the right way or the driver goes back up over the hedge. Still, provided you've had enough breakfast you never get a flat battery!
- Real name: John Gaunt
Hi Nick,
That's a great looking outfit you have there, looks like a late TS69 with the oil bath trip. I have one of those on EPIC bodies that I pull behing my Cat D7, although it could manage a much bigger plough. I imagine the YL183 wearing parts are getting difficult to find these days. I stocked up on EPIC wearing parts a few years ago and havn't regretted it !
I've also got a Marshall Series 2 Mk 2 wheeled tractor, and can relate to your comments about starting the beast.
I remember my son driving it at a local rally, and almost stalling it when he didn't dip the clutch quick enough. The engine was rocking backwards and forwards... it fired and the flywheel went clockwise for a turn, then fired again and went ANTIclockwise for a turn, then fired and did a turn clockwise etc... Luckily it finally made up it's mind which way to go, and also luckily, it was the correct way, phew !
For those not famailar with the Marshall (and other similar) engines, being single cylinder 2 stroke diesels, they will run in either direction, so you get 3f and 1r gear or 1f and 3r
