Does anyone know anything about the 8360 dash panel?
It will select between oil pressure and water temp but won't show fuel.
The main panel appears only to show forward speed, and incorrectly at that. It regularly reads over 100mph!
Why does the clutch not engage when the tractor is on full left lock? Turn the wheel the slightest amount to the right and it's away, weird stuff.
Again, any ideas appreciated.
Ford 8360 questions
Re: Ford 8360 questions
hair bear wrote:Does anyone know anything about the 8360 dash panel?
I would put that one up on one of the Farming forums. Do you not get any error codes?
- Real name: Paul Griffiths
- Has thanked: 384 times
- Been thanked: 256 times
all sounds to modern for me good luck with it all only thing I can think of is crook earths maybe ??????
Topic author - Posts: 992
- Real name: Rob
- Has thanked: 195 times
- Been thanked: 281 times
Spent best part of a day messing with it, no luck so maybe easier just to get someone else to drive it!
- Real name: Rob
Just to complete this, I never did fix the dash, but the clutch/steering issue was down to a worn/failing pump in the back end of it. I wasn't involved in fixing that so I can't give any more details.
