hi
just joined this site. am looking for a wiring diagram for 1989 case ih 885. downloaded workshop manual but unfortunately no wiring diagram . have tried the net and a few dealers here in ireland but no luck so far.can anyone help
thanks in advance
john.
1989 case ih 885 wiring diagram (with victor cab).
- Been thanked: 685 times
Re: 1989 case ih 885 wiring diagram (with victor cab).
Is the Victor cab the same as an LP cab? You could try on the British Farming Forum as there are some very knowledgeable IH guys on there.
If you are not a member you may not get an instant sign in.
- Real name: Norman
- Has thanked: 2 times
- Been thanked: 15 times
May also be worth a post on the David Brown Tractor Club forum as I think there was a fair bit of crossover at about this time with Case owning David Brown.
I know its not strictly Brown and to some DB fanatics Case is a four letter word but someone may be able to help.
http://www.dbtc.co.uk/index.php?name=PNphpBB2
essexpete wrote:Is the Victor cab the same as an LP cab? You could try on the British Farming Forum as there are some very knowledgeable IH guys on there.
hi. thanks for reply. not sure if its same cab but ill try on that forum.
Stormin wrote:May also be worth a post on the David Brown Tractor Club forum as I think there was a fair bit of crossover at about this time with Case owning David Brown.
ok ill try that . thanks.
- Real name: Richard
- Has thanked: 28 times
- Been thanked: 46 times
John, this is the XL cab or the low-profile (stockman-type) cab?
What part of the wiring info are you after?
RichardJW~ wrote:John, this is the XL cab or the low-profile (stockman-type) cab?
its a low profile cab. very little wiring in cab itself only lights and wiper. had to replace fuseboxes and rewire some of instrument wiring and engine loom. wiring diagram saves a lot of time by identifying colour codes, components fitted etc. i have the most of it sorted so far.most of the warning lamps were out of their holders as were cables from sender units as well.this where a diagram comes into play.also a red wire hanging near handbrake switch. i presume its off a sender for hydraulics just have to find out where.
