mechman wrote:Hi all.
I forgot to mention that while it was running yesterday I lifted the priming levers a tad and I could really feel the resistance (cammy) knocking against it,( the lever) but the lever on the non firing cylinder was practically horizontal before any resistance and very weak cammy wise. Hope that makes sense, and I also think this might point me to the pump having a weak or broken spring or whatever's inside It.
Norm
Hi Norm,
Two things come to mind. The tappet / plunger in the housing where the pump is mounted which operates the pump has been known to stick, not allowing the pump to return to the bottom of its stroke.
Also the tappet / plunger in the pump itself can stick, or the spring which returns it may be broken.
What I can't see though is how you would have been able to spill time both pumps if these faults were present.
It is important to check the calibration marks on the pumps before spill timing.
Below is a pic. I took and posted here a while back showing the mark on the pump rack. You will have to move the rubber boots on the rack to find them, ( if they are still fitted).
Slide the rack on the first pump to the flywheel end, make sure the rack extension is tight against the governor arm and adjust it to obtain the half inch clearance as shown in the pic. then without moving the first pump adjust the link between the two pumps to obtain the same setting on the second pump. The measurement is taken from the pump casting not the brass bushing.
