E83Wvince wrote:Hi
Fred answered a post I made a while ago since then I was struck down with the big C hopefully on the mend now it was to do with the brake mechanism I have a Fowell A type dumper and mine is missing has anyone got any pics of the handbrake setup.
ps anyone know what the torque settings for the head is on a Lister Petter AVA1.
Many thanks Vince
Hi Vince,
Sorry to hear that you have been down with the virus, but glad to hear you are on the mend. A lad that used to work for me was not so lucky it beat him, he was only 53.
The tightening torque for the AVA cylinder head is 60 ft. lbs. or 81 Nm. if you prefer, Be sure to put back the head gasket and shims as you find them or you will have to reset the piston bump clearance. I will explain how if you need to do that. Sequence for tightening the head below.
AS I think I said, there is no handbrake as such. The brake comes on when you push the pedal right down to disengage the drive, then move the gear to neutral and latch the pedal down to hold the brake on for parking. I have no pics but the drawing from the parts book below shows the ratchet and pawl attached to the lever that is used for that purpose.( Part Nos. CO4, CO5 and CO7).
Fred.
