I’m after the oil feed pipe for a 3cyl lister petter engine, part no 203-31671.
I’ve seen one on eBay but it doesn’t look new to me
Oil feed pipe
- Has thanked: 1887 times
- Been thanked: 1701 times
Re: Oil feed pipe
weirdfish wrote:I’m after the oil feed pipe for a 3cyl lister petter engine, part no 203-31671.
If the pipe is inside the engine which I would expect then even if it is used so long as it is good then it should be worth a punt, what is wrong with your old oil feed pipe?
Re: Oil feed pipe
The pipe comes up from the sump and feeds the top of the engine via 3 banjo connections.
The one I have is leaking and has been repaired very badly
- Has thanked: 303 times
Re: Oil feed pipe
If you can confirm the one you have found is in good working order with no leaks grab it. I would be cheeky enough to ask the seller if they will take it back if it leaks.
Re: Oil feed pipe
Just ordered a new one from a company that supply lister parts, hopefully that’s this problem sorted.
