thwaites 7000 sump oil rising dramatically
Topic author - Posts: 3
- Real name: Graham walker
- Has thanked: 3 times
the sump oil level is rising dramatically, is it possible for the hyd oil to leak into sump from hyd pump shafts seal on lister ts3 engine.
Re: thwaites 7000 sump oil rising dramatically
Graham, if oil rises in a diesel engine it can only be either hydraulic oil, diesel fuel oil, or power steering oil, while in this instance as there is no power steering pump then it can only be diesel or hydraulic oil.
With external fuel return it is unlikely to be diesel oil, how easy is it to remove the hydraulic pump, drain the engine oil and put fresh oil in then run the engine and see what happens?
Hope that helps.
Hope that helps.
This engine is fitted with a diaphragm type lift pump, That could be passing fuel into the oil if the diaphragm has failed.
- Has thanked: 302 times
Sounds like a diaphram has a split in it to me. What are your oil levels like? Has the hydraulic levels dropped? If not pull the fuel pump and put a kit in it and as suggested drop the sump oil and replace as it is now thinned with diesel.
FOWLER MAN wrote:Hi,
Thanks Fred I forgot that way in for fuel.
