Well I still don't know what it is .!
Topic author - Posts: 45
- Real name: Mark
- Been thanked: 4 times
Re: Well I still don't know what it is .!
Well spent the weekend working on it . Slowly working my way through the wireing . I hope to
o try and start it soon . A few electrical parts are missing . No voltage regulator . . Still some progress
- Has thanked: 302 times
At least a voltage regulator is not required to make it start. Off to the wreckers to buy another one.
- Real name: Mark
Not that easy . Three wire off the flywheel . Like a motor bike . I am currently looking in to it . Bit of a bag of worms at the moment . 8t looks like there is some sort of lock out of the coñtrols if not charging .. oh the pàin in my head ..
Is the regulator totally missing or not working?
What brand of alternator / generator is on the dumpy?
What are the colours of the wires?
You will need to know what wire does what. Red usually to + Black to - Brown or yellow to F from memory. I can look this up when required.
Old T Model Fords had a magneto behind the flywheel and that had wires coming out from it.
- Real name: Mark
Three yellow wires is what comes out perminate magnet type . So it's three phase . But that's the least of my problems .. lots to work out . Still think it was made here in Australia . Just hoping to get it started . Then the electrical. Lots of wires switches solinoids it's got the lot !!!
- Real name: Mark
Well just an update .engine is sick .I can't get it to go . Has a lot of blow by . So will have to pull it apart and have a look .lombardini .two cylinder job .. anyone got a source for parts. Not much available here in Australia .must be some aftermarket stuff somwhere .
Let me have a search for the supplier out here. I'm sure there is one somewhere and I'm not sure if it is a company named Minards at coal Point near Newcastle NSW. Do a search for them and make contact. If they dont have the parts they may direct you to someone who does. I bought some hard to get British seagull parts off them years ago and were good to deal with.
As for the blow by you may find that by freeing up the rings you will win. Before stripping try a dose of oil down the injector hole/s. Once running it might free the rings with some heat.
- Real name: Mark
Will try that .. it's just s bit of oil ... It fires on only one cylinder . There is lots of blow by . It has fuel but won't start . Something is just not right . Can get the heads and sump off without removing the engine .so that's a bonus . Ear elephants in thin slices !!!!!
