Barford SD 06
Posted: Mon May 14, 2018 8:33 am
Firstly thanks for adding me to the site.
I’ve had the above dumper a couple of months and put it through its paces.
In the process I’ve managed to snap the brass collar of the pivot ball on the change lever. As such the gear lever now moves from side to when attempting to change gear rather than backwards and forward.
I’ve found the parts manual online and the part number for the change lever and bolt is TF15/16.
The issue I’m having is find a supplier for the part. Can anyone recommend one. I’ve tried PES.
As a secondary question, it’s clear the collar was keeping the gear lever in place. If I was to have this brazed back to the pivot would it be strong enough? I have no experience with brazing.
Many thanks
Matt
Many thanks
Matt
