Stothert & Pitt Dumper..... Help required
Discuss dumpers here
olympus51342
Real name: mark
Post #1 by olympus51342 » Mon Apr 10, 2017 3:26 pm
Hi
I have a Stothert & Pitt Site rider4wd dumper. I need to replace the hydraulic tip control and wondered if anyone had an idea on who I may be able to purchase the parts from.
The third pic down shows the top view of the hydraulic control. On the middle section the end of the spool is broken off and the lever assy is broken
Mark
Has thanked: 498 times
Been thanked: 313 times
Re: Stothert & Pitt Dumper..... Help required
Post #2 by essexpete » Mon Apr 10, 2017 9:46 pm
I guess any single double acting spool will do with a built in relief valve , might need some adapters.
http://www.ebay.co.uk/itm/Hydraulic-Log ... 2619361337
You have to check whether or not it is up tom the job and it does seem cheap.
Has thanked: 1045 times
Been thanked: 934 times
Post #3 by FOWLER MAN » Tue Apr 11, 2017 11:08 pm
I think I'd have a go at repairing that. :think:
If your not into that sort of thing a good engineering shop may be able to help.
Alternatively I think I would look for a spool valve from another similar sized dumper which you can adapt. That will have the relief valve and all the connections you require, though you may have to adapt the fittings to suit your pipework.
There must be plenty of scrap machines in dealers yards :?: :?:
Yewman
Real name: Paul Procter
Has thanked: 4 times
Post #4 by Yewman » Wed Apr 12, 2017 12:19 pm
Would help if it had a name. Most vehicle manufacturers used proprietary valves, made by Plessey, Vickers, Hamworthy,
Danfoss etc.
olympus51342
Real name: mark
Post #5 by olympus51342 » Wed May 16, 2018 2:23 pm
thanks guys
sorry didnt get back to you.
i managed to fabricate the required part and now.... touch wood.... tipping like a good un
Return to “Dumpers”
