George Fowell OR Fowler Dumpers
- Has thanked: 302 times
Re: George Fowell OR Fowler Dumpers
Don't give up, be like me and 'never surrender' and you will get there. That being the case simply have the bearings honed out to suit your crank. If the engine is for display more than work than it will run another 80 years, if going back to work and under long full loads you will possibly get another 12 years. Use good clean oil to the correct grade recommended for your climate because here in Australia we run thicker oil in the Summer than you would in the Winter. I use SAE30 or similar on my Lister.
- Real name: Vince Punter
- Been thanked: 21 times
I don't give up while suffering chemo and really bad side effects I built this just to keep my mind working thanks mate
Beautiful workmanship and design. I have seen a very similar shape from the late 1950 to early 1960's of a professional fishing boat driven using a British Seagull outboard. A one man show would use it for prawning in the lakes and rivers near Coffs Harbour. A mate of mine bought it as a restoration project and got it to the same level of finish then sold it off to a Museum.
This was never built to sell I'm working on the paddle at the moment it's far from perfect but will do me
The engineer has been to measure the crank -40 will do he's going to hold the shells in the lathe and use a cylinder honing tool to remove 0.05 thou off each it won't be used everyday only when I need to pull something outside of the workshop thanks again
Wish I was at coffs harbour fishing
Sounds like a very good plan and best way to resolve your problem. That repair will last for a very long time. Hope to see some progress when it happens and take care of yourself too.
Hi I've now got the shell end bearings, small end. Piston rings, and I'm fitting a new oil pump. Might as well it's the only thing left as soon as I finish chemo I'll start working on it again thanks for all the kind words really appreciate Vince
Hi again I'm back from chemo not doing too bad considering
I'm dismantling the engine and it's those gib keys I've tried drifting them just mushes the tang I've tried heat nothing anyone got any ideas?
regards Vince
regards Vince
- Has thanked: 1883 times
- Been thanked: 1696 times
Finally got the engine back together and running tried to put a little video on here but it won't let me I'll get some pics next week I have the makers plate with my engine number and chassis number also a pat pending number
Hi Vince, glad that you are on the mend and back in action. Sorry I have not offered any help with the gibb head keys as I have had endless trouble logging in etc but now all good again.
With posting videos I post them on my YouTube account then add the link here. It is the easiest way I know how. Look forward to seeing some pics and possible video.
