hi all
I'm new here
I have a Benford dumper, with AVA1 petter motor
Unfortunately I do not know what type and which construction year.
He has already changed my belt drive.
I am looking for belt and belt for motor.
i.a.knapp@gmx.at
Old Benford Dumper
Re: Old Benford Dumper
Hi Stefan and welcome I would imagine that a drives and bearings supplier may be able to help you out with a drive belt, hope that helps.
- Real name: Rob
- Has thanked: 194 times
- Been thanked: 281 times
Hi Stefan,
Not an educated guess in any way but after sifting through some pics I would suggest maybe a Benford 750, 1965ish.
Wonderful scenery you have there!
Hi
Thanks for you all reply.
Yes, this is a Benford 750 of 60th year.
But I do not know where or who can I ask for belt and pulley.
I've sung in the ebay belt, was 4 years ago for sale, but no one bought.
I sent a message to the seller, maybe he still has this part.
Everywhere search forums and always ask whether from where I can get rid of, but no one knows.
Have a nice day
Thank you hair bear it is a beautiful district. Much mountain and beautiful country
Regards
Stefan
Have a nice day
Regards
Stefan
Hi
It was with flat belt drive, but in the engine is a normal belt pulleys.
The transmission is still the original flat belt pulleys. So used.
I want to re-install the original flat belt. So is original and so works right.
I need for engine a pulley and the right belt. But I do not know what length (3 "belt). I do not know diameter for richige pulley for engine.
That's why I need someone who knows.
- Real name: Hugh Reid
Hi all I own the same old dumper and am also in need of a drive belt. Did you obtain one ? If so where from please? Any info gratefully received.
- Real name: jan delooze
- Has thanked: 66 times
- Been thanked: 2 times
hi i own the same dumper with 3 inch belt cluch
the top pulley is 4 inch diameter(101.6mm) x95mm long. note if you change diameter you will change final drive ratios on all gears
the botton pulley has a flange on either side to keep flat belt on pullies which suggests pullies are square and not barrel types
my cluch belt is 3 inch wide (75mm x 4mm thick) try www.stationaryengineparts.com plus you need No 20 size joint or use there jointing service
you need to check their belt is suitable for a minimum bend radius of 2 inch which is your smallest driving pulley
if you put a length of string around both pullies without being affected by the tension pulley this is the short length ie might drive all the time
if you put a length of string around both pullies and round tenion pulley with tenion pulley max in ie max tensioning position this is the long length
you need a length some where between these to lengths
when you press the cluch pedal the tension pulley ie the middle one should move away from drive pullies and make belt slack which is how cluch works
regards
jan
regards
jan
Users browsing this forum: Google Adsense [Bot], XS650 and 39 guests
