I recently got given a KH36 excavator to use as long as I could fix it, new battery, belt, filters, oil, a good clean and a hell of a grease later it works! Only the water pump has a leak... can anyone tell me the Part number I'm looking for (for a new pump)? I have not got the engine document or any parts lists so can't find it. I believe it is Z620-KW engine if that helps?
Thanks!
Kubota KH-36 water pump
Topic author - Posts: 1
- Real name: Colin Bannon
Re: Kubota KH-36 water pump
Noticed you'd not had a reply.
I can supply these pumps.
Contact me if you still need one
Last edited by Martyn Henley on Tue Oct 22, 2013 7:20 pm, edited 2 times in total.
Reason: Removed links
