JCB 3CIII tapping to run accessories
Topic author - Posts: 7
- Real name: Jim Beagley
Hi all. Does anyone know if there is a hyraulic outlet on my trusty JCB 3CIII to run accessories. I would like to run a logsplitter off it if possible. Ive had a quick look and I can't see anything obvious. Are there good places to tap into for the feed and return?
Re: JCB 3CIII tapping to run accessories
Would this point work? I’m guessing it’s for testing the hydraulic pressure?
- Has thanked: 1887 times
- Been thanked: 1701 times
Jim, I am no hydraulics expert but that looks like a quick hitch for a hydraulic hose, however there is no return so I am guessing and I may be wrong here that connection may be used for measuring the pressure from the pump? If it was for a take off you would still need a return.
Hi Jim,
It's a long time since I played with one of these.
You can tap into the system anywhere on the pump delivery line shown in your pic. Trace it through and find the easiest place to "T" in.
The line runs from the pump to the loader valve block which also houses the main relief valve. It runs on from there by way of the high pressure carry over tube, (pipe), to the right hand end, (looking with your back to the engine), of the digger valve block. That may be a good place to tap in.
The return, (exhaust oil pipe), should be connected into an original return line to insure that oil returns to the reservoir through the return line filter in order to protect your system.
There is an exhaust oil line running from both the loader valve block and, if I remember rightly, the left hand end of the excavator valve block.
You will need a pair of self sealing couplings to connect your splitter lines.
Good luck.
Fred.
Good luck.
Fred.
