Hi, I was wondering if anyone could help me? I have a JCB 3csII 1976, the universal joint for the propshaft which drives the hydraulics is very worn, will one off a 3cx fit or does anyone know where I can get a replacement from (new or good second hand)?
Would be grateful for any info on this.
Universal Joint for propshaft which drives Hydraulics on JCB 3csII
Topic author - Posts: 30
- Real name: Chris Davies
- Has thanked: 4 times
- Real name: Mark Rive
- Has thanked: 33 times
- Been thanked: 26 times
Re: Universal Joint for Hydraulics on JCB 3csII
Hi Mr Bounce, certainly the the UJ was still the same as yours on 3CX machines up to M459999. Maybe later!
JCB Part number is 914/10803. For your info the size of the uj is 82mm over the caps with 27mm diameter Cheers Mark
Re: Universal Joint for propshaft which drives Hydraulics on JCB 3csII
HI, thanks for the quick reply, there is part on ebay can you tell me if this is the one I need? Ebay Item number: 250693057866.
Thanks again.
Thanks again.
valvebounce wrote:HI, thanks for the quick reply, there is part on ebay can you tell me if this is the one I need? Ebay Item number: 250693057866.
Thanks again.
Yes it should do. I have used Digger parts before (Darren) and found them very helpful, real quick reply via e-mail too. Should mention I am in no way connected with them! Mark
P.S. If you give them the part number they will cross reference.
Thanks for that Mark it was a big help. Do You know the part number for the fan/alternator belt for my 3CS11 1976 engine number 36271. Thanks Chris
ps Happy New Year..
ps Happy New Year..
valvebounce wrote:Thanks for that Mark it was a big help. Do You know the part number for the fan/alternator belt for my 3CS11 1976 engine number 36271. Thanks Chris
ps Happy New Year..
Happy New Year to you too......... JCB P/No for belt is 988/00153.
Dont forget to buy 2 and tie wrap the second one out the way Mark
Hi Mark, thanks again that good advice to buy two. I am going to check the tappets at the weekend, do you know the valve clearance and what method used to check them ie. rule of nine, or on the rock etc. Sorry to be a moither.
Thanks,
Chris.
Thanks,
Chris.
valvebounce wrote:Hi Mark, thanks again that good advice to buy two. I am going to check the tappets at the weekend, do you know the valve clearance and what method used to check them ie. rule of nine, or on the rock etc. Sorry to be a moither.
Thanks,
Chris.
Hi Chris, its all in here. JCB 2D, 2DS, 3, 3C, 3CS, 3D and 700 Backhoe Service Workshop Manual
follow the link and download the manual to your computer Cheers Mark
