Last Thursday was a disaster where I worked hard and quickly accomplished nothing
One irritating job that has needed doing on the 580BT was that there is a crack in the undercarriage tub, these are quite common and a previous owner has splattered weld on the tub like its going out of fashion, the tub had cracked along this weld, additionally they have welded on a towing eye which I could not face grinding off.
I dug the crack out with my angle grinder and would have had a bash at welding it myself but Andrew kindly MIG welded this for me after which I ground it down a bit , then cleaned it off and primed it, then top coated it, job done, so at least today I got one useful job done, result.
I'm not too sure if you will see the crack on the photos or not?
