Hi Guys, newbie here!
I have a hydraulic leak on my control block joysticks, just thinking of stripping top cover plates to investigate.
Does anyone have any experience of a repair/ replacement?
I don’t even know if I can source parts, maybe I am wasting my time stripping out?
The plungers are leaking as they move up and down.
Thanks for looking
Regards
Gary
Powerfab 1200 X
Topic author - Posts: 6
- Real name: Gary Lynex
- Has thanked: 1487 times
- Been thanked: 1306 times
Re: Powerfab 1200 X
Hi Gary and welcome
I would imagine that removing the cover plate will let you see what the issue is, even if the valve block was leaking it could be stripped and new seals put into it, have a look first it may be a simple pipe connection that is leaking.
Re: Powerfab 1200 X
Jeremy, thanks for the reply.
Pipes are pretty sound, definitely the spool seals leaking.
I stripped off the cover plate today, I can clearly see the seal behind a small steel retaining ring.
Only thing I can't work out is how to replace?
The plunger is a larger diameter at the controls connection, getting the old seal out looks straight forward enough; but installing the replacement not so obvious?
I have had trouble uploading pictures so difficult to explain.
Can't even find any replacement parts for powerfab.
Kind regards
Gary
Kind regards
Gary
Re: Powerfab 1200 X
Gary,
You may be better off taking it to a local hydraulics engineer; it's hard to offer advice when you cannot see the actual component, you can try uploading pics again, simply click the "upload pic" tab above, then click on the "choose file" tab and you can then select the photo you want directly from your device, then click on the "upload" tab, then click on the "upload all images and close" and the photo or how ever many you have selected should appear listed below you typing, once you click the submit button the whole lot should be posted. Hope that helps.
Re: Powerfab 1200 X
Jeremy, I have tried without success to upload images, also tried different devices to see if chrome made any difference.
Once my images upload, I just see a text file path rather than images.
Any further advice would be appreciated.
Regards
Gary
Regards
Gary
Re: Powerfab 1200 X
Guys, I have just cracked the image upload.
So I sorted the seals on the control block spool valves.
Please view the cylinder in the image, I also have a hydraulic fluid leak from the top of the cylinder when you slew around. I just need to know if I strip out the cylinder can I repair or am I likely to be wasting my time?
I fully degreased and none of the hoses are leaking, fluid emerging from between the rotating cylinders.
Any advice or thoughts greatly appreciated.
Regards
Gary
Regards
Gary
Re: Powerfab 1200 X
Hi Gary glad you finally cracked how to post pictures
as for your leaking rotary coupling, yes you should be able to pull it apart okay and I'm guessing here that you will find some 'O' ring type seals in there, from the look of your photo it looks like the lot may be held in by the large circlip which is visible. My main advice would be to make sure that your hose connections are clearly marked along with the coupling position so that it all goes back together the correct way around.
Just check the bore of the coupling once you have it apart but hopefully new seals should cure the leak, let us know how you get on with it.
Re: Powerfab 1200 X
Jeremy, thanks so much for your speedy reply.
I am very grateful for you having taken the time to reply.
I will crack on with the investigation and inspection of the relevant components.
Regards
Gary
Regards
Gary
