stevejcb wrote:By this time the rain beat me – so I gave up (my best day of the year - is summer!) will try removing the head tomorrow?
Question – I know the principle of cranking an engine, ie: - put a socket on the crank end and turn it with a bar – my problem is that there is no end of crank ie: it has a power drive fitted to it. Therefore what do you suggest that I do to turn the engine when adjusting the valves, when I get to put them back? Sounds daft but...
Hi Steve two things; firstly the one injector has pulled the water jacket copper sleeve out, these are normally rolled to expand them in the cylinder head so you will probably need to take the head to an engine specialist or find somebody who will lend you the tools to do the job.
Secondly to turn the engine you may be able to turn the fan by carefully applying a bit more pressure to the belt; best set it up before the injectors go back in then it will be easy to turn over; finally good luck.
