This is the job I did in the 1990's,overhauling V12 diesels as fitted to Class 37 frieght locos for BR.
They were 1750 horse power and had two turbos and two intercoolers.engines made by English Electric.
We used to strip them down and renew all the worn componants on the locomotive.It took about 4 weeks to do a 10 yearly exam and overhaul.The engines were then put on a "load bank" , this run the engines in and adjustments were made to the governor and fuel settings.We then took the locomotive for a light run,no train attached, to check out control systems and brakes etc.
When we were happy with that,it was put on a loaded train up to 2000 tonnes to check that every thing was ok.It was then put into regular service.I was involved with 20 rebuilds on this type anf 16 on the V16 Ruston Paxman diesels.
These locomotives were truely classic British built locomotives that gave very good service from 1964 to present.
Click on photos to enlarge
English Electric diesels
Topic author - Posts: 6393
- Real name: Julian
- Been thanked: 13 times
Re: English Electric diesels
It looks a tight squeeze working on them, I take it you left the engines in the locos rather than removing them?
I always thought the Paxman (Valentas?) were V12 - what locos got V16's? (so I can search the youtube to listen to one
Julian.
Julian.
- Has thanked: 1883 times
- Been thanked: 1696 times
Julian try listening to this one I think its an English Electric but it does sound sweet:
http://www.youtube.com/watch?v=Nlk0AjvT6yY
Its a very tight space to work in.when you are my size The engines on the class 37 were left in, but to answer your question,the V16 were in the 3300hp class 56.We used to remove them and had one under rebuild at all times to speed up down time.The engine in them weight 39 tonne.My favorite engine were the SULZER LDA 28C.They would beat all your GM's and Cat engines for engineering.
The Paxman Valentas were V12 and used in the HST's and the Royal Navy.These have been replaced by the German built MTU's
I have also worked on Maybach V12 and V16,these had the best sounding engine ever in my opinion when under load.These were also used in boats.
I was glad we stopped doing the V16,s as they were hard to work on and I still get the aches and pains in my joints from my time on them.
Found this on youtube of a pair on test,coupled in multiple on a 2000 tonne coal train.
http://www.youtube.com/watch?v=OiM-i_p5wSk
From the drivers seat
http://www.youtube.com/watch?v=94OXBPs2Kg0
The Class 40 locomotives is of the same type that was involved with the 1963 great train robbery.It has a V16 English Electric fitted with four turbos
Class 52 powered by two Maybach MD655's pulling 600 tonne passenger train,note how speedy from a standing start these locos could attain as it leaves Bristol.
http://www.youtube.com/watch?v=brXAUc2GgL8
Return to “Workplaces/Job reports”
