Re: carnage 3ciii
Posted: Sun Jul 11, 2021 6:43 pm
A little bit of progress, I noticed when checking the top dipper linkage pivot had no grease nipple, so I decided to remove it and sort it out, as I'd left it assembled as one unit with the dipper linkage/arms/bucket craw ram when removing it.
The bush + pin was pretty bad, and the arm bushes also. I dug the 3c2 linkage out and got the bushes from that, and found a good pin to use, retapped the grease nipple while it was apart and fitted a 90deg grease nipple and bingo nice working joint now. One more off the list.
Also got my finger out and sorted those hoses out. If anyone needs to know the trick to get access to them to replace, slide the kingpost to one side, and remove a wheel, big lump of something solid under the H posts and work inside the wheelarch.
Next job is a toss up between welding on the main filter door from the 3c2, and the cab...
