Eveng all!
I am looking for a little help with a benford terex pedestrian roller i am trying to revive.
She is quiet poorly at the moment. I can get her to move forwards but not backwards. And vibrate seems to not work at all.
Hoping someone has parts or overhaul manual?
Anyone clued up on the machines?
On the plus side it has a hatz electric start engine which fires up and runs ......... so theres a starting point!
Regards Lee
Thanks in advance for any help.
Benford terex roller
Topic author - Posts: 17
- Real name: lee
- Has thanked: 3 times
- Been thanked: 3 times
Re: Benford terex roller
Been investigating today seems the bearing may have collapsed in the vibration generator.
I dont think it should be toching tge frame like it is in the photoabove .
Lee
Lee
Hi Lee, you may be correct there, is it my imagination or can I see cracks in the cast housing? It's still not beyond repair though.
- Real name: Ian Perrott
- Has thanked: 90 times
- Been thanked: 88 times
Hi Lee
I've just got a S&P v44 vibroll back from the dead so don't give up hope! The vibrator shaft on mine is offset so when it spins when the clutch is engaged it gives the vibration, looks as though yours may be bent? The vibration works by cable and when the lever by the forward reverse controls is operated it engages the clutch on the side of the roller to drive the belt, it may be its stretched or seized?
With regards to the forward and no reverse, they are operated by a hydrostatic drive motor manufactured by eaton, they are operated by a belt drive and inside there are two races with ball bearings in, one is a delivery side and they operate on pressure, mine wasn't driving but I could see the motor was attempting to move so i took it off and stripped it down, be careful as the one side the ball bearings have springs in and when you strip it down they fly everywhere!!!, I just gave it a good clean and replaced it with new 15w30 engine oil and I was lucky enough that it drives no problem, it may be that it's been topped up with oil and it has an airlock? I have manuals for spares for the mbr71 and the eaton transmission overhaul if you supply me your email address i will gladly forward them to you
There's a video on youtube showing the strip down of the eaton hydrostatic drive they are used on walker hydrostatic lawnmowers in the USA i think if you type in walker hydrostatic drive in the search it will come up
Ian
Ian
Found the documents
Here's a link to the spares for the benford terex roller
http://constructionsupport.terex.com/_l ... Spares.pdf
And the one for the hydrostatic pump
https://www.eaton.com/ecm/groups/public ... l_1618.pdf
- Real name: lee
Jeremy Rowland wrote:Hi Lee, you may be correct there, is it my imagination or can I see cracks in the cast housing? It's still not beyond repair though.
Ah see what you mean but theres alot of mud in the bottom there. Lots like is cracked in pic but its ok thankfully.
- Real name: lee
Whitlock 505 wrote:Hi Lee
Ian
Thanks so much for your help.
I will have to gen up on the hydrostatic drive and strip it down.
As for the colapsed bearing it looks like deap surgery i that i will have to dismantle the drum to get to the inards of the vibration shaft and its bearings.
Regards lee.
