Some sheduled maintenance
- Real name: nicky
- Has thanked: 89 times
- Been thanked: 223 times
Re: Some sheduled maintenance
The flywheel housing that came off was,as expected, abit worn on the lip where the engine mount had fretted against it.This would be easy enough to repair but I had another in mint shape so just used that instead.Got 2 new mount brakets off Roberts Plant that were better than mine.
- Real name: nicky
TC likes to clean things up nice and tidy.'Near enough' just ain't in his way of doing things.
- Real name: nicky
Afterwards,it was just left to Dad to swing it in for TC.That old JCB isn't too sweet in the response department .After that I reackoned Tony was ready for a pint or two.
I'll post that on my other thread.
Hope the operators got the right ticket fancy letting him drink on the job
Great pics
Great pics
Topic author - Posts: 1440
- Real name: nicky lamb
- Has thanked: 7 times
- Been thanked: 43 times
I have had to get them both ear muffs Jeremy as I often go down to the quarry on a saturday morning with them.There is allways some blade work to do and those D8's are abit on the loud side...
- Real name: clive gray
- Has thanked: 174 times
- Been thanked: 242 times
Get the ones with the radio in them, they're great and the kids love them!
- Real name: nicky
I was very lucky to have a virtually brand new torque in my stores and it required just one bearing that TC wasn't too happy about.He's overhauled the torque divider gears and fitted the lot back in.
Whilst the cab and belly plates are off we have pulled out the tranny to have a look just in case.I wonder what's in there?
Clive,do you know when it was last done and by who?
No idea, Steve never did it. He bought the tractor in 1997 from Barry Pope. Not sure if he performed any surgery!
I'm glad you had some bits which made the job easier on the pocket!!!
- Real name: nicky
Thanks Clive.
We stripped the tranny down to find a missing thrust washer.The pinion oil feed had also worked loose but no damage has been done.Overall the tranny is in good order apart from the pins in one of the carriers.The clutch plates are pretty worn so thwy will be replaced by ones in my store.Two big ring gears aren't really good enough to put back into this tractor so will be renewed.I have spare ones in the tranny shed but the cost of the new ones doesn't really justify the cost of stripping another tranny down to find them.
Have serviced the tractor today and fitted new fanbelts and the cab has had a coat of paint inside and out.
