cat d6d bulldozer
Discuss dozers here
senives
Real name: Senyonjo Ivan
Flag: Uganda
cat d6d bulldozer
Post #1 by senives » Fri Apr 07, 2017 12:51 pm
hi guys
am having trouble with my cat d6d machine. It works for just 2 hours then it stops. it has automatic transmission system. i have tried so many things but if anyone has insight on this machine pliz advise. Am also in need of workshop manual for the same machine . thanks
mechman
Real name: norman orrick
Has thanked: 22 times
Been thanked: 34 times
Re: cat d6d bulldozer
Post #2 by mechman » Fri Apr 07, 2017 6:22 pm
Could it be something simple like a vacuum in the fuel tank/
Mrsmackpaul
Real name: Paul Griffiths
Has thanked: 382 times
Been thanked: 252 times
Post #3 by Mrsmackpaul » Sat Apr 08, 2017 11:22 am
when you say it stops do you mean the motor stops running or the transmission stops working
If its the motor I reckon Norms suggestion above would be a good spot to start , maybe the air vent has been blocked with mud wasps or something simple like that
A good place for the work shop manuals is ebay you will find all the info you need there
senives
Flag: Uganda
Post #4 by senives » Sat Apr 08, 2017 1:34 pm
thank you mechman and Mrsmackpaul for the participation. by stopping i mean the engine runs normally but the machine cannot move. i have checked the following. reassembled entire transmission changed converter and scavenger pump, changed transmission pump and all filters plus strainer. when i start the machine, it works well for 30 minutes and stops however it floods transmission hydraulic into the flywheel housing all the way to the self-starter.
Return to “Dozers”
