TD9B Track seals
TD9B Track seals
Can anybody point me in the right direction for new track tensioner seals for the grease pump up tensioners on my tracks on my TD9B. I don't mind if they are overseas I am happy to pay freight if the prices are right. I have not removed the old seal yet so don't know if it is able to be matched up at a hydraulic or bearing shop. If it is anything like my MF200 drott, they are quite unique.
Re: TD9B Track seals
You could try your first option and try to get a set fron a seal/bearing supplier.There is a good chance of getting a set.Also try the Redpower boys.Rocko 59 is the one to ask,he has just joined us on this site.He has a wealth of knowledge and may be able to suggest a supplier.
Also Ebay,sometimes you may get lucky.I have some new IH seals but would need measurments of your original ones.
Also try Barry Welch, Staines Middlesex.
Good luck
Good luck
- Real name: Jim
- Has thanked: 5 times
- Been thanked: 20 times
Hi Ash,
I have usually had success with local seal suppliers.
Also check the rod is in good order...if they are corroded,grease will slip past.
I hope that fixes your problem.
Jim
Jim
Users browsing this forum: No registered users and 51 guests
