Page 1 of 1
Mini Digger
Posted: Tue Feb 11, 2014 9:35 pm
by Jeff Hall
Hi All,
We have just purchased a mini digger which we are led to believe is a Volvo Peljob 1 ton powered by a 2 cylinder diesel engine. It looks an old machine but digs quite well even tough there is a considerable slop in the bushes. It also has a lot of movement in the slew.
Please can anyone advise how we tighten the movement in the slew, and where would I be able to obtain a manual on this machine
Many thanks
Jeff
Re: Mini Digger
Posted: Tue Feb 11, 2014 10:45 pm
by bigkit
Hi Jeff, try volvo for a manual, digbits offer cheap aftermarket pins and bushes that should do you. As for side play, well more importatent it has n't got up and down play in the slew ring. Grease it up well and give it a go. Slew rings are available service exchange. The side play maybe down to the slew motor, check its bolted up tight. Good luck.
Re: Mini Digger
Posted: Tue Feb 11, 2014 11:01 pm
by Jeff Hall
bigkit wrote:Hi Jeff, try volvo for a manual, digbits offer cheap aftermarket pins and bushes that should do you. As for side play, well more importatent it has n't got up and down play in the slew ring. Grease it up well and give it a go. Slew rings are available service exchange. The side play maybe down to the slew motor, check its bolted up tight. Good luck.
Thanls Clive
Re: Mini Digger
Posted: Tue Feb 18, 2014 9:35 pm
by Jeff Hall
Hi how do you measure for a replacement track
Jeff
Re: Mini Digger
Posted: Sun Feb 23, 2014 8:03 pm
by wiggy
if its a rubber track some ware on it will b a size
but if you get on 2 digger bits they shuld be able to sort you out with what you nead to do
Re: Mini Digger
Posted: Mon Feb 24, 2014 10:28 pm
by widget
These guys might be able to help, I used them years ago give them a call for advise
http://www.southernplantspares.com/rubber-tracks.html
