Mini Digger
Jeff Hall
Real name: Jeff
Mini Digger
Post #1 by Jeff Hall » Tue Feb 11, 2014 9:35 pm
Hi All,
We have just purchased a mini digger which we are led to believe is a Volvo Peljob 1 ton powered by a 2 cylinder diesel engine. It looks an old machine but digs quite well even tough there is a considerable slop in the bushes. It also has a lot of movement in the slew.
Please can anyone advise how we tighten the movement in the slew, and where would I be able to obtain a manual on this machine
Many thanks
Jeff
bigkit
Real name: clive gray
Has thanked: 174 times
Been thanked: 242 times
Contact:
Re: Mini Digger
Post #2 by bigkit » Tue Feb 11, 2014 10:45 pm
Hi Jeff, try volvo for a manual, digbits offer cheap aftermarket pins and bushes that should do you. As for side play, well more importatent it has n't got up and down play in the slew ring. Grease it up well and give it a go. Slew rings are available service exchange. The side play maybe down to the slew motor, check its bolted up tight. Good luck. :thumbup:
Jeff Hall
Real name: Jeff
Re: Mini Digger
Post #3 by Jeff Hall » Tue Feb 11, 2014 11:01 pm
bigkit wrote:Hi Jeff, try volvo for a manual, digbits offer cheap aftermarket pins and bushes that should do you. As for side play, well more importatent it has n't got up and down play in the slew ring. Grease it up well and give it a go. Slew rings are available service exchange. The side play maybe down to the slew motor, check its bolted up tight. Good luck. :thumbup:
Thanls Clive
Jeff Hall
Real name: Jeff
Re: Mini Digger
Post #4 by Jeff Hall » Tue Feb 18, 2014 9:35 pm
Hi how do you measure for a replacement track
Jeff
wiggy
Real name: mark wignall
Been thanked: 10 times
Re: Mini Digger
Post #5 by wiggy » Sun Feb 23, 2014 8:03 pm
if its a rubber track some ware on it will b a size
but if you get on 2 digger bits they shuld be able to sort you out with what you nead to do
the older the plant , the more i like it ,
im dislesik so escuse my spelin gramer
I crushed my spine years ago and im soposed 2 b in a wheel chair
so every day when i wake up and my legs still work is like crimbo day
widget
Real name: Richard
Has thanked: 529 times
Been thanked: 175 times
Re: Mini Digger
Post #6 by widget » Mon Feb 24, 2014 10:28 pm
These guys might be able to help, I used them years ago give them a call for advise :thumbup:
http://www.southernplantspares.com/rubber-tracks.html
