Turns out it's got a lister SR1 engine. I removed the head and gave it a de-Coke, ground in the valves. Bump clearances were wrong. It was on a 20 " piston with no bore wear!!! Runsweet now and starts very easy even in the winter. Replaced the steering box with a Land Rover series three, overhauled the rod / drum brakes and replacecd an oil seal on one of the half shafts. Tin work was shot blasted and repainted. Bit more to do-but these old dumpers are great projects.
Liner site dumper
- Has thanked: 302 times
- Been thanked: 138 times
Re: Liner site dumper
You have done a nice job on the restoration. We feel we have the same model but with the SR2 twin cylinder engine in it along with a Newage Coventry 3 speed gearbox. We have no ID tag on the rear panel near where you crank start but have serial numbers of the engine, gearbox and what appears to be a chassis number stamped on a brass tag fixed to the floor area behind the bin.
Any clues as to where to look for more info will be greatly appreciated.
John
John
Hi. My first post on here. I have just bought a Liner Roughrider after many years of looking for one with decent tinwork. I believe this to be a late 60's early 70's 23CWT with a Lister LR2 Engine. My intention is to sympathetically restore it. (Does anyone know the correct yellow colour?) The engine starts and runs but the cold start is stuck on at the mo.
I was very impressed by the brass plate with the engine instructions thereon!
- Real name: norman orrick
- Has thanked: 144 times
- Been thanked: 132 times
Hi and welcome.
Plenty of dumper crack on here.
That looks pretty intact, from the pics it looks as though the drive wheels want swapping over. Any pics of the cold Start?
Norm.
Norm.
Yeah, very nice project to play with and yes front wheels are on the wrong side unless you are working on a sealed surface for long periods of time. Years ago I used to swap the rear wheels of my back hoe over when doing a lot of work on a sealed road, it did extend the tyre life.
- Real name: craig
- Has thanked: 156 times
- Been thanked: 374 times
That is a very original one I 'd keep it as it is , great patina which you can only have once !
May I ask why you were seeking one out .
Craig
Craig
Thank you for your welcoming comments. The front wheels were quickly put on by the previous owner and will be swopped round soon I managed to spend some time and investigate the running problems. Popped the cover off and found the problem. The pin and retaining clip which connect the rods together had dropped out. Luckily they hadn't gone far so I popped them back in and now she starts, stops, and runs like a good 'un!
Users browsing this forum: No registered users and 43 guests
